SOVOL Zero USB File: https://drive.google.com/drive/folders/1p9mJHD5e1oecqEHyl00ozbOIZg2Amm2Z
SOVOL Zero firmware:
https://drive.google.com/file/d/1qDfbWjtpul_71hG3dV1iTpFBuFQfX2Ri/view
SOVOL Zero image file(Need to use EMMC-adapter):
https://drive.google.com/drive/folders/1VEGNVrzIzNWNtfgLcCZwv8I73Jwz_MqN
EMMC-adapter order address:https://www.sovol3d.com/collections/fdm-parts/products/makerbase-mks-emmc-adapter-v2-usb-3-0
Download:https://github.com/Sovol3d/Sovol-OrcaSlicer/releases/tag/v2.3.0
Configuration files:https://github.com/Sovol3d/Sovol-OrcaSlicer/tree/main/Profiles/Sovol Profile
Document:https://github.com/Sovol3d/Sovol-OrcaSlicer/tree/main/Document
Orcaslicer import configuration file (Windows)
Orcaslicer import configuration file (Mac)
How to avoid clogging when printing low temperature filaments
How to use OTA to update the firmware of SOVOL Zero
Unable to connect to WIFI
Update firmware and flash image |
Hotbed L and R height calibration |
### Fixed
- Added WIFI network configuration service function, used with network configuration tool
- Support query of wireless network wlan0 hardware status information, activated connection information, network speed, can execute common network commands, and can manually disconnect wifi
- Removed the coordinate information printed on the web page when the net bed is leveled
- Added LED light to the chamber heating module. The indicator light is off under normal circumstances, and the indicator light is on when the chamber fan is not rotating
- Added USB plug-in log file usbmount.log in the logs directory
- Updated wifi driver
- Fixed the error of model cooling fan that can only appear when the web page is opened
- Added temperature fan to set the temperature function
- Optimized the macros of ending printing, canceling printing, continuous printing without material, and net bed leveling
Cancel the use of pressure module and add eddy current contact home calibration function
Update the nozzle adapter firmware to adapt to the eddy current contact zero calibration function
Modify the purging filament action to adapt to the eddy current contact zero calibration function
All input shaping types are open
Add chamber module configuration. The feature is disabled by default
Changed the original fan3 to the temperature-controlled exhaust fan
Fan3 configuration, pin changed to PE14
-The prompt code is 125 when exhaust fan doesn’t rotate
-The prompt code is 110 when chamber module fan doesn’t rotate and automatically turns off chamber heating
